Brief Description: shorten the avionics dimmer pot shaft
Manual 42M-05 steps 4 and 5 - shorten the dimmer pot 1/8" using Dremel cutting wheel. Installed the potentioometer and attached the knob. Did not tighten the pot or the knob
Applied Krylon appliance white touchup paint to a couple small spots on the engine mount where the powdercoat paint was damaged while mounting the engine mount.
