Greg's RV-12 Classic N719VA
RV-12
42C, SL-00010
wire up GPS, install connector on CO monitor
Manual 42C-07 steps 5 & 6, install cushoined clamps and route GPS cable through the firewall from FWF (firewal forward) to instrument area.
Manual42C-08 steps 1 - 3, add d-sub to GPS wires and attach to module. Added label from label maker per the structions. GPS already applied by Dynon.
Manual 42C-04 step 4 connect connectors to transponder and the AV-50000A control module
SL-00010 Wire up the d-sub onto the CO monitor module. Found two d-sub shells to use that I had in my electronic parts.
FWF GPS wiring
GPS and xponder cables
xponder cable to xponder
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
