Brief Description: install pitch servo, drill hole for AP stop switch
Manual 44A-04 steps 2 - 6 install the pitch servo, electrical filter, wiring etc. Torqued the pushrod to 30 in/lbs attached to the flaperon controls. Applied torque seal.
Manual 44A-05 step 2 drill to 1/2" the mounting hole for the Autopilot cutoff switch. Will install and connect the switch when the rest of the avionics are installed.
