Brief Description: taxi, ELT work and rear window prep
Did more taxi testing and brake conditioning, they worked well and held with full power. Radio worked well when engine RPM and temp were below 120. Had bad squeal and unreadable reported by others when engine was hot and at higher RPM. Must troubleshoot.
Installed and connected the ELT , installed batteries in the remote and audio announcer. ELT remote gave an error code when connected, will change to reversing cable to test. Installed antenna as well, cut away some of the wrap on the antenna mount to insure ground conection to the antenna.
Finished putting in the tongue depressors between the turtle deck skins and the rear window to create a gap for the sealant.
