Checked the 35-06 step 6 instruction to add wire tie to hold the brake lines. Done okay.
Replaced the two wing rollers F-1204M and aluminum bushing to ensure the rollers would roll sloothly when installing the wings. Torqued the bolts to 30 in-lbs. Rollers roll smoothly.
Slightly bent the Spar switch brackets to ensurethe switches are closed when the spar pins are properly installed. Works okay now.
