Greg's RV-12 Classic N719VA
Date:  6-29-2020
Number of Hours:  1.00
Manual Reference:  31B
Brief Description:  clean-up wire/tube bundles under 7 thru panel base
Cleaned up the wire/tube bundle under and through the avionics panel base and around the rudder peddle controls. Need to retorque the 6 bolts holding the dudder controls. had loosened them to hopefully give more room for wiring/tube to be routed.
bundle wiretied
bundle wiretied
bundle wiretied near panel base
fuel flow sensor connector
