Greg's RV-12 Classic N719VA
Date:  5-13-2020
Number of Hours:  1.50
Manual Reference:  34-10
Brief Description:  canopy latch handle rotation tightening
Manual 34-10 after not able to squeeze the ltch shft as instructed to get friction on the rotation of the canopy latch handle I decided to use two plastic washers on the bottom portion of the latch handle inside the fuselage. I could have used two of the C-671 washers called out for the top of the latch but did not have them. So used two 3/8 ID plastic washers and drilled them to 1/2" to fit over the shaft. This worked perfectly. Had to clamp the handle down a bit to allow handle screw to insert properly but when done it works very well. Nice even friction. Added grease for corrosion and waterproofing per the instructions.
washers on bottom of latch
washer on top of latch
washers used on bottom
