Greg's RV-12 Classic N719VA
Date:  4-10-2020
Number of Hours:  1.25
Brief Description:  investigate brake line bleed process, etc.
Spent time verifying that the Royco 782 hydraulic fluid I purchased from Vans Aircraft wil work okay with the Matco brakes supplied in the RV-12 kit. Emailed both Matco and Vans for verification. Received reply emails saying this will work fine.
Replaced two seals supplied with the ATS brake bleeder tank assembly with EPDM seals as required by the instructons when using a synthetic oil.
