Brief Description: Polish and attach control stick bushings
Manual 32-05, step 4 & 5 completion - polish the inside of the control stick tube and the brass bushings that slip inside for a more friction free fit. Applied some Boelube to the brass bushings. Inserted them and bolted together. Did not torque do to castle nut. Had to add a washer on the bolt head side for proper spacing to occur for the cotter key to work with the castle nut.
Manual 32-05 step 6 partial, started to attach the control stick push rods to the control sticks but very difficult to hold the washers allowing assembly. Gave up after about an hour.
