Greg's RV-12 Classic N719VA
Date:  9-15-2022
Number of Hours:  6.00
Manual Reference:  PAP
Brief Description:  Tested pitot/static ports, reduce idle
Tested the static, pitot and AOA ports per the PAP - All worked perfectly, virtually no leakage at all.
Adjusted the engine idel settings reduced by 1/4 turn turn and retested - idle now down to 1650 when warmed up.
Did magnetometer calibration per the Dynon procedure and PAP T1-1. No compass rose but used combination of the east west north south cracks in the taxiways.
Did final install with velcro of the baggage compartment upholstery. Will install top piece later.
Rear upholstery done
