Greg's RV-12 Classic N719VA
RV-12
sand fit canopy, cotterpins on mains
Sanded the canopy trailing edge to get the 1/32" gas to the rear window.
Bent the main gear wheels cotterpins as required.
Test fit and modified the center tunnel cover to fit over the wiring and brake line tubing. Installed trim and siliconed it down.
Sanned the left side of the canopy where three screws go. Will finish later.
Manual 34-25 checked the canopy latch and applied Teflon tape.
cotterpin fastened
RV-12 Home
2007
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
