Greg's RV-12 Classic N719VA
RV-12
final tension of stab cables,misc.
Rechecked the horizontal stabilator cable tensions. Used Kent-Moore BT-33-750 cable tensioner for readings on the 1/8 cable scale.
Manual 32-14 step 8 inserted the locking clips into the turnbuckles. Made sure they are in and locked and took close-up pictures to verify.
Manual 37-09 step 2 trimmed and cleaned the tank sealant from the inside of the fuel filler tube.
Torqued the two seat belt back cable attachments to the fuselage to 65 in-lbs
Applied the blue wrap to the ELT antenna mount bracket.
clips locks in-place
clips locked in-place
RV-12 Home
2007
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
