Greg's RV-12 Classic N719VA
RV-12
open talcone fairing hole
Manual 12-11, opened the bottom clearance hole in the tailcone fairing for clearance with the trim servo assembly linkage.
Removed more protective plastic from the wings.
Tested Dremel timing bit for use on the flaperons for clearance to the fuselage.
RV-12 Home
2007
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
