Greg's RV-12 Classic N719VA
Date:  12-15-2021
Manual Reference:  35, 21
Brief Description:  verified wire tie, replace wing roller bushings
Checked the 35-06 step 6 instruction to add wire tie to hold the brake lines. Done okay.
Replaced the two wing rollers F-1204M and aluminum bushing to ensure the rollers would roll sloothly when installing the wings. Torqued the bolts to 30 in-lbs. Rollers roll smoothly.
Slightly bent the Spar switch brackets to ensurethe switches are closed when the spar pins are properly installed. Works okay now.
