Greg's RV-12 Classic N719VA
RV-12
49 and 50
finish oil hoses, start install of throttle
Manual 49-17 step 6 finish - wiretied the VA-213 and 215 hoses together, verified all oil 6 hose fittings are tight.
Applied a small amount of clear RTV to bottom seal of air duct to allow for proper sealing when the cowl is installed.
Manual 50-02 step1 and 2 grind flat edge on throttle lock washer to clear the bottom portion of the instrument panel.
wiretie on VA-213 and 215
RV-12 Home
2007
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
