Greg's RV-12 Classic N719VA
RV-12
finish cowl heat shield foil, install oil hose
Manual 49-16 finish step 4, cut foil heat shield #4 and applied to cowl. Applied epoxy resin mix around the foil edges.
Manual 49-17 step 5 install oil hose VA-215, ned to rearrange due to improper fit and clearance.
RV-12 Home
2007
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
