Greg's RV-12 Classic N719VA
Date:  8-30-2021
Number of Hours:  3.00
Manual Reference:  49
Brief Description:  cut paper templates for foil cowl heat shield
Manual 49-13 opened the drain hole in the air duct interface that was closed when the seals were applied.
Manual 49-16 steps 1 and partial 2 - layed out the paper templates for the foil heat shield pieces. Test fit the bottom cowl with the templates taped inside. Determined that I need to order more foil to get good coverage of the cowl from the heat.
Copyright © 2001-2022 Matronics. All Rights Reserved.
