Greg's RV-12 Classic N719VA
RV-12
disconnect the Rotax ignition connectors, etc.
Manual 46-02 steps 1-7 disconnect the ignition wires and several scews, etc.
Manual 46-03 steps 1 - remove and install new scew and spacer. Torqued to 55 in/lbs based on Rotax requirement for that screw size.
ignition wires disconnected
new screrw installed (black)
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
