Greg's RV-12 Classic N719VA
RV-12
none
filed parts for better wing fit, reverse connector
Reversed the right side fuselage connector for proper fit to right wing.
Filed the plastic wing retainer by 0.040 inches for hopefully proper wing insertion fit, remounted, torqued bolts to 35 in/lb. Applied torque seal.
Filed very little off of the left side fuselage inside aluminum blanking plate for proper wing insertion fit.
Ready to try to test mount again when the weather allows.
RV-12 Home
2007
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
