Greg's RV-12 Classic N719VA
Date:  5-7-2020
Number of Hours:  1.75
Manual Reference:  40-05
Brief Description:  figured out problem with wing connector
Figured out the left wing wiring connector was installed upside down. (oops, I was so careful). That is why I had to remove the wing connector to allow the wing to insert further into the fuselage, connectors would not mate correctly. Wiring is correct. See 40-05 verified that the right wig is corrctly installed. Switched the left wing connector.
Also figured out the the right side fuselage connectoris upside down.
Copyright © 2001-2023 Matronics. All Rights Reserved.
