Manual 34-16 step 1 partial, used a Dremel style tool with a small grnding ball and other pencil tip to gring away opening to remove the hinge bolts. Made sure canopy was free from cowlings using the flat burr removing tool. Lifted the canopy high enough to disconnect on one end of the struts that hold the canopy open. If this is not done then the struts want to push the canopy forward after removing the hinge bolts. Removed the hinge bolts and with help of wife removed the canopy and placed on a table. Ready to trim.
Still need to enlarge the bolt head holes in the canopy plus trimming. Is very cold in the garage so will need to wait until a little warmer to continue.
