Greg's RV-12 Classic N719VA
RV-12
remove middle pealply, sand and fill gaps
Manual 34-15 step 5, removed pealply from the middle. Start sanding with 60 grit on both sides. Filled in gap areas with fast cure #206 epoxy/microbeads mixture.
left area filled in w/epoxy+beads
right area filled in
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
