Manual 35-07 step 5 and 6, tighten the nose wheel fork compression bolt and adjusted to 19 lbs of pull both directions. Installed the nose wheel onto the fork. Tightened bolt as instructed.
Cheryl pulled out the saw horse and dropped the nos wheel onto the floor. Now the fuselage can be moved around the garage or taken out side while Cheryl pushes me around and I make airplane noises. Sadly will have to wait for the weather to get warmer to do that.
