Greg's RV-12 Classic N719VA
RV-12
Bolt on mains axles, attached wheels
Manual 35-04 step 1 finish, bolt on mains axles with one 3/4 degree shim on each side. Torqued the bolts to 80 in/lbs.
Manual 35-04 steps 3 and 4, Install the main wheels and the brake assemblies. Torqued brake assembly bolts to 100 in/lbs.
wheel and brake assembly
side view
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
