Greg's RV-12 Classic N719VA
RV-12
Finish second main tire and assemble brake conn.
Manual 35-02 steps 6-8 finish the last main gear tire and wheel hub. Torque all bolts to 100 in/lbs per Matco, pump to 28 psi.
Manual 35-02 step 10, install brake system fittings in two attach brackets. Use Loctite 567.
brake fitting brackets
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
