Greg's RV-12 Classic N719VA
Date:  5-19-2017
Number of Hours:  3.00
Manual Reference:  32-05
Brief Description:  Polish and attach control stick bushings
Manual 32-05, step 4 & 5 completion - polish the inside of the control stick tube and the brass bushings that slip inside for a more friction free fit. Applied some Boelube to the brass bushings. Inserted them and bolted together. Did not torque do to castle nut. Had to add a washer on the bolt head side for proper spacing to occur for the cotter key to work with the castle nut.
Manual 32-05 step 6 partial, started to attach the control stick push rods to the control sticks but very difficult to hold the washers allowing assembly. Gave up after about an hour.
right side control stick
left side control stick
