Greg's RV-12 Classic N719VA
RV-12
install brake reservoir
Manual 32-02 steps 1 - 3, mount the brake reservoir, torque to 35 in/lbs, apply torque seal.
Connect brake lines. Had ro reroute lines behind the wiring.
Install brake lines clamp, torque to 35 in/lbs.
reservoir in engine compart.
reservoir connections
brake lines clamp behind wires
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
