Greg's RV-12 Classic N719VA
Date:  1-21-2017
Number of Hours:  3.50
Manual Reference:  31B-22 & -24
Brief Description:  install fuel pump elec. filter and wing fuse conne
Manual 31B-22 steps 1 - 3, (steps 4 & 5 later), install the fuel pump elecrical filter. Will finish ths page after installing the tail cone due to aft pitot tube part of the tail cone.
Manual 31B-24 steps 1 - 5, attach wing wire connectors to brackets, brackets to fuselage and attach covers. Had to modify slightly the right side bracket to fit the connector correctly. Had to drill out the fuselage mounting holes for the connector brackets to #21 for #8 screws to work. Deburred holes.
left side wing lighting conn.
right side wing wiring conn.
left side wing wiring cover
