Greg's RV-12 Classic N719VA
Date:  1-20-2016
Number of Hours:  2.50
Manual Reference:  28-04 & 28-05
Brief Description:  fabricate and install pump to valve fuel line
Manual 28-04 steps 1 - 5, fabricate F-1259E pump to shut off valve fuel line. Had difficult time running the line through the second hole grommet. Had to sand the inside of the grommet some. May have to tweak the line a bit near the shut off valve when installing the fuselage clamps for proper fit.
Manual 28-04 partial steps 1 - 2, install fittings and plugs into fuel flow sender and gascolator using Loctite 567. Had to purchase an allen wrench set for the plugs. Ordered a safety wire pliers set for step 2.
ouy going fuel line at pump
pump to valve fuel line via fuse
fuel line in at fuel shut off valve
