Greg's RV-12 Classic N719VA
RV-12
27-05 & 27-06
put fuse on side, run remaining brake lines
Manual 27-05 steps 1 - 5, install fittings on lines and run brake lines through fuselage, clamp and attach to master cylinders.
Manual 27-06 steps 1 - 2, install fittings on lines and attach reservoir brake lines to master cylinders.
brake lines complete, clamped
brake lines at bottom access
brake lines in fuselage tunnel
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
