Brief Description: install brake line fittings and crossover lines
Manual 27-04 step 4, install the brake line fittings onto the master cylinders. Used Loctite 567 as suggested by the master cylinder manufacturer and on Vans Air force forumns.
Manual 27-04 steps 1 - 3 and 5, fabricate crossover lines and install. Had to heat each fitting multiple times with boiling water to complete the fitting assembly onto the lines as directed. Did not use Loctite or any other compound on the line fittings.
