Greg's RV-12 Classic N719VA
Date:  10-23-2014
Number of Hours:  3.25
Manual Reference:  15-07 steps 1-6
Brief Description:  redo rear spar rivets, install front rivets rt win
Cleco and rivet front main ribs and spar on right wing.
See 14-03 notes in my plans. Modify bottom row and 3 up from bottom on the right rear wing spar doubler W-1207B inboard end. Replace surface rivets with CS4-4 flush rivets. This is done to avoid possible interference with flaperon. This was done per suggestion by Scott Malcomb (RV-12 builder, Eagles Nest) at Oshkosh 2014 and Vans Aircraft email. See picture of finished mod. on left wing on 8/6/14. Here is body of email from Vans to Scott approving this mod:
> From: "Joe Blank"
> Date: November 6, 2013 at 1:54:04 PM EST
> To: Scott Malcomb
> Subject: Re: RV-12 - Section 39
> Scott,
> I ran the issue by both Van and Rian here. Both agreed that the offending rivets could be replaced with CS4-4 rivets to alleviate the interference issues. The rivets are predominantly in shear to the head shape should not affect the strength much.
> Another possible fix would be to lightly file the heads to remove any rough edges.
> Best Regards,
> Joe Blank
> Airshow Coordination - Builder Support
> joeb@vansaircraft.com
> www.vansaircraft.com
> 503-678-6545
right wing fron ribs
right wing front ribs and spar
