Gils Web Site
Date:  8-11-2017
Number of Hours:  55.00
Brief Description:  The panel
The magnetometer mounting caused me quite a few headaches. We were getting heading errors from the G3 X, regularly. I thought that the magnetometer was generating these errors. So the picture illustrated here is the first location that I used to install the magnetometer. It has been moved three more times since this photo was taken. As it turns out the problem was not generated by the magnetometer. Rather, the GTN 650 was the cause of all the problems! Which went away after Garmin replaced the unit.
Panle installed not yet wired
Powered up
Powered up
the assumed suspect
the assumed suspect
