Fabricated the parts for the elevator electric trim. Nutplates installed on the reinforcing brackett, cover plate was match drilled and the holes were dimpled for #6 screws. Played (quite a bit) with the servo to get it in the precise alignment and where (once attached) it will allow the assembly to be installed and removed without destroying anything. Once satisfied, drilled the attach flanges and prepped them for riveting. Also, using a Dremel grinder, I trimmed the edges of the nutplates where they impeded the installating/removal of the servo. Primered all the parts. Assembled and test fit the assembly that night.
After much trial fitting, the electric trim servo is attached to the cover plate.
