GEOFFREY'S WEB SITE
Date: 3-14-2009
Number of Hours: 4.00
Brief Description: Rudder trailing edge
Enough has been written on this subject to fill up the www. Rv trailing edges. I didn't do anything earth shatteringly different. Obviously, every step is important, and if any one of them is screwed up the trailing will end up, well, screwed up. I used a piece of 3/16' aluminum angle as my clamping bar. After match drilling the angle with a skin, I placed the aex wedge on the very edge of my workbench and drilled and clecoed it to the bench. Now I was abled to countersink the wedge because the edge of the countersink can hang over the edge of the table and I was able to get nice, consistent countersunk holes as the drilled holes in the table provided pilot holes for the microstop countersink. Then, using a marker, I labled each of the holes of the rudder trailing edge in the order of the pattern I wanted to rivet them in. Knowing that I was going to rivet every hole in the opposite direction.#1 on one end, #2 on the other end, #3 in the middle, #4 between #1 and #3, #5 between #2 and #3. Then I just kept splitting the difference until every-other hole was numbered. Flipped it over and did the same pattern on the remaining every-other holes. Next I mixed up the Proseal and spread a layer on the wedge. Placed the wedge between the skins and clecoed the whole mess to the pre-drilled aluminum angle and set it aside to dry for several days.
By drilling and clecoing the wedge to the edge of the table, the countersinking is fairly easy.
The trailing edge glued and clamped.
Get the Proseal even and make sure the clecos set fully.
