Brief Description: Drained Fuel Tanks to Determine Unusable Fuel
Drained any remaining fuel from each tank out carb inlet hose through paint strainer. No debris in paint strainer found. Then drained each tank from the low point drain on each tank through paint strainer. No debris found in strainer after draining each tank. Weighed the drained amount from each tank.
