Painted right wing with Ranthane True Blue with accelerator.
Mixed 4 batches at 2 parts blue : 1 part cat at 3 parts on mixing cup. This requires ~6.2 oz of base blue for each batch. Added 6 ml (CC's) of accelerator to each batch of catalyzed paint. Then reduced 1:1. This yielded about 17 oz of sprayable material for each batch. This was my mistake, thought I was reducing 3:2. Turned out to be dumb luck! Smoothest paint finsih to date.
Mixed final finish batch at 2 parts on mixing cup. Added 4.4 ml accelerator and reduced 1:1. Had about 1,5 oz left over after spraying wing with one light coat and two medium coats.
Ended up using ~30 oz of color base to complete right wing.
Had small problem with pinhead fisheyes on first two coats. Waited more than the required two hours after wiping with C-2210 solvent. Not sure what caused this. Seemed to cover on final coat.
