Had an issue with heat shrinking of the heavy fabric. The shrinking of the fabric caused the bow of the elevator to compress. This resulted in the opening of the trim tab to shorten. Had to make an "adjustment" for trim tab clearance.
Rib stitch the right elevator using the staggerwing stitch. Started applying tapes on right elevator.
Sprayed last coat of Poly Spray on both horizonal stabilizers and rudder. Wait 2 hours. Sparayed two coats of Poly Tone (Federal Gray) on both horizontal stabiliers and rudder with 2 hour wait between coats.
