Ky Bearhawk Construction site
Bearhawk
Wing Assembly
9-9-2014
Right False Spar
Finished installing the right false spar. It is now completed. Next I need to weld up the greese fitting nuts on the aileron drive because both sides has a pin hole that grease will shoot out of when greasing the tubes.
Bearhawk Home
464
Aileron/Flap
Metal Brake
Priming
Spars
63
128
Wing Assembly
43
84
Wing Ribs
45
104
Wing Steel
