Ky Bearhawk Construction site
Bearhawk
Spars
5-25-2011
Spar attach angle spacers
I finished drilling holes and deburring the rear spar attach angles. I then started back on the main spars by attaching the vertical spacers using a single double flush rivet in the middle of each spacer.
spacers attached
flush rivets are harder to do.
Bearhawk Home
464
Aileron/Flap
Metal Brake
Priming
Spars
63
128
Wing Assembly
43
84
Wing Ribs
45
104
Wing Steel
