Brief Description: Finish Main spars Start Rear spars
I only recorded it for 3 hours today but I did build my second table. I spent three hours rebuilding my metal brake, bending the rest of the main spars and cutting out the flap spars and rear spars. All 4 main spars are now in the c channel config and ready. I am going to go ahead and cut and bend all the spars before proceeding. This way I can remove the metal brake and get the use of the entire table back. Had to stop early today as the wife is sick and I had to fix supper for the boys. You know its bad when they come down to the building to get you and tell you that they are hungry.
