I got both flap drive mechanisms and flap hinge mounts bolted in. Put a coat of paint on one side of the flap torque tubes. Started to mount the aileron bell cranks but my bolts were to short. I ended up using washers for a spacer between the bearings. I like this better than trying to cut and grind a small piece of metal to do the same job.
