Brief Description: Aileron Pocket Ribs and False Spars
Spent a bunch of time cleaning the shop then once that was somewhat under control I got some time in on the wing assembly. I went ahead and riveted the aileron pocket ribs into location. I did not do the ones that will no be ligned up with center ribs as I am not sure where they will go yet. I went on to the false spare and clecoed in place the fuel tank strap reinforments after opening the holes up with a #30 bit and deburred them again. Discovered I need to order some more rivets to accomplish this as I was out of the correct length.
