Brief Description: False Spar tank mounts and flap supports
Did some different things today. First I drilled and deburred the reinforment strips on the false spar where the fuel tank straps will mount to. Drilled them to #40 when later I realized I need to take them on out to #30 so I will have to debur again. Then I welded up the support tubes for the flap torque tubes. I put them into place and the right wings spins well but the left wing is still in a little bind so I will need to work on it some more. I put the wing strut attach bars in place and temped the bolts in to keep them in place.
