Brief Description: Root flap torqe tube support construction
I started trying to get the support tube installed at the wing root. Forgot about this many times in the process and had already installed support angles. Rivets had to be drilled out and now I am having to figure out the best way to make the brackets to hold it all together. Still not happy at this point. Also started drilling out some rivets that I did not like on the spar.
Trying to figure out the best way to accomplish this task
