Was able to weld up the brackets that go on the tip end to support the spar. Ethan actually welded up alot of this and I just observed and helped him. Once they were welded and cooled we clamped them to the angle iron and placed the main spars on them. I put a 2x4 in the middle to help support the spar because I did not like how it was bending in the middle under its own weight. We then clamped the aileron and flap drive stuff to the front spar and clamped the rear spar to the other end. This was all done roughly without alignment at this time. Already I can tell this is going to be alot more interesting than making 170 ribs.
