Brief Description: Putting the wing assembly jig together
Started measuring out post spacing and assembly of the 2 2x4x12 into one peice. I screwed the posts together every 6~8 inches the full length on both sides. I also placed the wood where the grains would be opposite of each other. The lumber was untreated and kiln dried to minimize the amount of additional warping that would happen. If I find that it is twisting or turning I will mount a peice of angle iron the full length to the backside of the post to keep it from moving.
