Ky Bearhawk Construction site
Bearhawk
Attach Angles
All attach angles for the flaps are made and pre drilled for the ribs and the .025 are predrilled for the spar. I will match drill the .032 to the spar. Should be able to assemble the flaps quickly then I will be ready to prime.
.032 on the right, .025 on the left
Bearhawk Home
464
Aileron/Flap
Metal Brake
Priming
Spars
63
128
Wing Assembly
43
84
Wing Ribs
45
104
Wing Steel
