Almost completely done with. I just need to take a drum sander to the inside where the bearings go to cleanup that area after the welding. These parts take some time to make as you have no fixture to put them in and you have to make sure they are straight in many different angles. They were fun to make though. Very small for the amount of work it takes to make them. I also decided to not do the flap torque tube root support peice until I have the wing all jigged up. I want to make sure there is no friction from mis alignment.
