Started the completion process of the bell cranks. As you can see in the photos the recess was made on a lathe. This is the first part I have had someone else make for me. I made the slits in the tube using a dremel and cut off wheel. I just put the part in the vice to make sure my slit ran parrallel to the top and bottom of the bearings.
